spiridij
- Apr 23, 2015
- 37
I have a 3 story home with an un conditioned third floor (with an insulated attic above that). I'm obviously losing a lot of heat to the third floor in the winter since all three floors are connected by stairs without any doors separating them. As a result the first two floors are never as comfortable as I'd like. If I were to heat the third floor would that cause less of the heated air from the first two floors to rise to the third floor since there's a lower driving force pushing it up if I set the thermostat at a higher temp on the third floor? I'm thinking about adding a ductless system to the third floor, and I'm wondering if it might actually help make the first and second floors more comfortable as well. Same question for air conditioning in the summer. Any thoughts?
John
John
