JRoutley
- Oct 8, 2024
- 1
Recently ran into a foundation contractor who pours his footing + stem walls monolithically and uses horizontal rebar set directly ontop of his footing forms to hold up the stem wall forms. After the pour he has essentially #4 bar that will forever stick out of the stem wall and beyond footing face by 1"(after forms are removed). I have never seen anything like this however he claims he has done it this way for 30+ years and no inspector or engineer every questioned. Per builder the bar is not used as reinforcement and doesn't make contact with structural bars inside wall to avoid corrosion. Thoughts?
