I am required to provide anchorage information for a couple residential propane tanks - 1150 gallons each. They look similar to the tanks you find at the gas station propane refill.
ASCE 7-15 requires 8x diameter gauge for steel anchors in concrete (such as an embedded sleeve), in addition to concrete breakout and pull out being higher than steel failure (SDC C and up).
Some members of the construction team and propane supplier sent some stuff out pertaining to "eye bolt" location. Before I go ask them what the hell an eye bolt is for, I thought I'd ask on here. I'm assuming an eye bolt would be to strap the tank down perhaps? But that doesn't meet ASCE requirements. Is this a common way tanks are anchored? Are most residential propane tanks anchored ignoring ASCE 7 requirements?
