Residential Roof Trusses - 3-pt bearing ?
ReverenceEng
81
Hello all!!
I have a simple hip roof home, simple rectangle, but it's about 45 feet across in the truss (short) direction.
Although I know trusses can span this far, it's going to give me some large beams where we have some large openings on the side. My loads aren't terrible though - Roof dead is about 15 psf anticipated.
I am wondering if this might be a good candidate for 3-point bearing. I have a pretty decent line that goes own the middle of the home - would just require 1 beam and 1 small header, and then of course a continuous foundation, but this is a slab on grade with thickened edge, so nothing terribly cost consuming.
Does anyone have any general rules for when to go for 3-pt bearing? What are some decision points that influence the decision?
Thanks much!
Roof pitch.
Transportability.
Overpass heights.
To name a few...
Mike McCann, PE, SE (WA)
Just remember that a continuous truss will deliver most of the roof load to the internal bearing wall.
And in addition to the issues listed by Mike, they will be spindly to erect. I would think two simple spans are preferable.
agree with hokie about the two simple spans...that is how I've always done it and seen it done. A quick call to your local truss supplier can be very helpful for questions like this as well.
I would put my money on the truss guy rather doing it in two trusses as well
