phamENG
- Feb 6, 2015
- 7,272
Looking for some opinions. Who bears the responsibility of crack control design, particularly in a residential setting?
In many residential projects, the architectural "permit set" and the structural drawings are completed and submitted while the architect works with the owner to finalize finishes (and other non-code impacting items) to save time. Or...they never do it and it's left for the contractor and the owner to work out directly during construction. Sometimes after the slab is already poured. This makes crack control design nearly impossible. A crack control design for a floating vinyl floor is going to be very different from thin set tile, since the latter will telegraph any cracks and the joints have to be coordinated carefully with the tile. Add in the random geometric changes, influence of finishing (or not...it is residential), etc., etc. it feels like a fool's errand to even make an attempt.
I'm thinking of switching to a general crack control specification that gives maximum joint spacing and details, but doesn't provide a detailed plan of joint locations but also leaves other options open (like fiber reinforcement) to allow the contractor to select the best method for whatever gets decided after I'm left out of the loop (because I don't usually know a house has been built until I a) drive by and see it or b) there's an issue on site). But I'm hesitant to drop below the standard of care if, indeed, the standard is that I should meticulously work out crack control for every house.
