LockeBT
- May 9, 2021
- 55
Typically when it comes to stability check for foundations I use service loads (pretty much ASD loads). Without a geotechnical report my presumptive soil capacities (from the IBC or the CBC) such as soil bearing is taken without any factor.
However that section and Table 12.13-1 provides Resistance Factors for Strength Design when it comes to stability check.
For a retaining wall with seismic load there is no point using this. Not only am I getting a huge reduction in my soil capacities, my seismic load is now E instead of 0.7E and my soil loads would be 1.6H. Basically the demanded is factored up while the capacities are reduced.
I'm leaning towards designing everything in LRFD (Strength Design) since the codes are slowly and uniformly moving towards that direction (besides Wood) however that section seems like a double penalty. There is no point checking soil stability in LRFD then?
Anyone has any take on this?
