Mohamed Zied
- Jul 15, 2020
- 43
I have a bridge model made of two parts: the steel structure and the concrete deck assembled together using tie constraint.
The model works normally. but since it is a non-composite bridge, I want to assess the stress in each part (steel girders and concrete deck) and mainly the bending compressive and tensile stresses. In the visualization module, I only can see the assembly. In addition, I couldn't understand which stress results should I use: S11, S22, Max in-plane...
Your help is highly appreciated.
