bhiggins
- Oct 15, 2016
- 148
Hi everybody,
I frequently get asked to evaluate older retaining walls, and I'm trying to develop some typical cost-effective reinforcement details for walls deemed inadequate. For context, I'm currently assessing a 4-foot-tall reinforced concrete cantilever retaining wall that's approximately 30-40 years old. Although I haven't yet inspected the footing condition or confirmed the presence of a keyway, let's assume for discussion that the existing wall is undersized for sliding or overturning stability.
Normally, I'd specify concrete repairs or enlarging the footing, but this could become invasive and expensive. I'm therefore exploring simpler alternatives—specifically, reinforcing the backslope with layers of geosynthetic fabric or something similar to reduce lateral earth pressures on the wall.
While I'm experienced with conventional retaining wall design, mechanically stabilized earth (MSE) systems are new to me. Here's a sketch of my initial concept—could anyone comment on this general approach? Specifically, if the backfill layers behind the wall are fully wrapped in geosynthetic fabric, would this effectively reduce lateral pressure on the wall to near zero, assuming adequate frictional resistance and wrapping integrity?
My understanding is this approach should significantly address sliding and overturning concerns, provided global stability is acceptable. Could someone confirm or share insights on this assumption? Additionally, are there recommended resources or references you'd suggest for calculating loads and verifying this configuration?
Thanks in advance for any input or guidance!
