nxprog
- Jan 11, 2004
- 86
Has anyone found an efficient/correct way to use reuse parts in other reuse parts to create reuse assemblies? Some of the reuse parts are simple assemblies themselves. I have found that for the Part Name Management dialog/settings to work all the reuse parts that are included in the assembly must be in the same folder. The Part Name Management dialog doesn’t appear to recognize the “as saved” load options. While the components of the assembly will load and clone, but the naming rules won’t work…unless …they are in the same folder.
