CivilSteve
I have a project I am helping with and I was just wondering if anyone has every re-used a casing pipe or carrier pipe in a project before? We need to make sure that the casing pipe can be re-used and we can just pull out the carrier pipe. Typically, out here in the southwest the casing pipe is filled with sand once the carrier pipe is in place. Is there an easy way to get the pipe out of the sand or another method that doesn't involve sand?
Thanks in advance to all your time and help!
