reuse objects attributes
kaikiste
3
I'm currently working on a "part builder" which should build up a part out of single reuse objects.
This is working fine for the manual process inserting all the objects one by one and applying the Reuse Paste dialog.
I saw in the Siemens documentation that different attributes can be set for reuse objects, like REUSABLE_OBJECT_FEATURE_SET_NAME or REUSE_BOOLEAN_TYPE.
Especially REUSE_BOOLEAN_TYPE would make sense for me if it would do what I understand it is meant to be.
Instead of every time selecting the Boolean operation in the dialog it would be nice if this attribute would predefine that.
But it is not working for me.
Any idea?
In the end I'm aiming for an automation of the process to build up a part out of reuse objects.
Any idea how this could be handled? I'm currently see an NXOPEN tool doing that.
Kai
Hello....
no ideas on that one?
greets
Kai
The REUSE_BOOLEAN_TYPE att must be used on solid bodies not on part att.
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
