PDHPP
Chemical
- Apr 16, 2009
- 5
Dear All,
The interpretation of the new API-521 regarding the failure rate of two check valves in series (as 4.4.9.3) is leading to missunderstanding and need your technical support
Foe example for the clean boiler feed water and high pressure BFW-Pump (50 Barg. discharge press.), asssuming both check vlaves are properly maintained and inspected (spare pump is running):
a) In the past: No leak for inspected check valves (of different type!)
or
b) New: 10% of the flow (as 4.4.9.3.3.)
Which scenario a) or b) shouild be used for capacity of the SV on suction side ?
Thanks in advance
or
Thanks in advance
