3DDave
Aerospace
- May 23, 2013
- 11,238
pmarc mentioned:
The only reference that is tangentially connected seems to be in Geometric invariant theory, but that has to do with transformations as in
per
Is there some source of information about how "revolute invariance" came to be included in a discussion of Y14.5.1?
Per that chart, a cylindrical feature primary and a planar feature secondary will resolve in so called revolute invariance class which will be associated with a datum axis and a datum point lying on that axis (the point will be located at the intersection of the primary axis E and the secondary plane D) - similar to the scenario of a conical feature defined as primary datum feature.
Invariant theory is concerned with a group action of a group G on an algebraic variety (or a scheme) X. Classical invariant theory addresses the situation when X = V is a vector space and G is either a finite group, or one of the classical Lie groups that acts linearly on V. This action induces a linear action of G on the space of polynomial functions R(V) on V by the formula ...
per
