Cylindrical surfaces have two lines that, in display modes:
"Shading with Edges" - visible
"Shading with Edges without Smooth Edges" - not visible
when importing model (no difference between CATPart or STP) in Ansys, cylindrical surfaces are divided into two and, for example, there is a problem to set preload (Bolt Pretension), direction of which is supposed to be set by one cylindrical surface. If you have SpaceClaim, you can remove these extra lines and merge two surfaces into one, but I don't have it.
Why are there ribs on cylindrical surface at all? Is it possible to remove these ribs with Catia settings?
