Rigid attachment or nozzle? WRC 107
ElCidCampeador
IT
acc. to WRC 107, when does a nozzle could be considered as "Rigid Attachment"? Maybe when integral reinforced?
In other words, what is the difference between "solid" and "hollow" attachment?
Thank you
Just a comment ....
I hope that you are aware that WRC 107 is ancient history and has been both superseded and supplemented by other WRC Bulletins
MJCronin
Sr. Process Engineer
WRC 537 is the updated version of WRC 107. It essentially turns all of the WRC 107 graphs into polynomial equations.
For attachments to a sphere, there are separate graphs for a solid or hollow attachment.
For attachments to a cylinder, there are only graphs for a solid attachment.
WRC 107/537 does not cover hollow attachments in cylinders (i.e. nozzles).
You need to use judgement/experience to decide if a nozzle in a cylinder is rigid and reinforced enough to be considered a solid attachment. Otherwise use another method such as WRC 297, EN 13445-3 section 16 or FEM.
