nikolastrojman
Industrial
Hi all!
Does anybody of you guys have any experience with installation of rigid hangers on a line which has big thermal displacements and consequently swing angles bigger than > 4° which is accepted worldwide as a industry standard for rigid hangers?
We would of course avoid this problem normally by installing rigid supports, but unfortunately in this situation it wasn´t possible as existing steel structure (without proper reconstruction) can only accommodate for the use of rigid hanger
I want to be sure that nothing will happen to rigid hangers if we have swing angles of 7°/8°/9° depending on the location of the support.
Any suggestions for this situation and how to approach this issue?
