RamiHabchi93
1-Is it good to use a flexible mat foundation with a rigid superstructure?because it is more economical. I am modeling the flexible raft as a slab on elastic soil, and have checked the differential settlement and found them in the limits.
2-Could you give me a formula that help me determine if the superstructure is rigid or flexible?(for a raft for e.g L<2L0 means the raft is rigid, with L0=sqrt(4EI/kB),is there any similar way for the superstructure?)
