patelam
- Jan 27, 2022
- 36
I have designed a simple structure in RISA 3D and have used the software to design column (vertical) elements. On checking the detailed design report for columns in RISA, the flexural design in major axis does not accounts for lateral torsional buckling. It says "Limit state of lateral - torsional buckling does not apply".
Can someone explain if there is the code regulation that restricts the software to design for lateral torsional buckling or I am missing to input the parameter in the model?
