RisaFloor Error code
Sam1993
30
hello,
I was trying to draw a one simple wood wall on grids then I doubled click on the wall I got an error says that : wall panels must be rectangular, coplanar and no longer than .5 feet (Error code 2129)
Any solution to this problem?
My guess is that you've got a node that out of plane with your grid that you're clicking on, or which the program thinks you're clicking on.
I tried to change the type of wall or draw new girders but it doesnt work
The type of wall wouldn't matter.
What type of view are you in when drawing the wall? Elevation, plan view, or what?
If you're in a plan view, then is the floor sloped or flat? And, what's the distance from that floor to the ones above and below?
I am on the plan view and distance is 12 ft
Did you import the project from revit? Also try rounding off point coordinates. Depending on how the existing points were created originally (from revit) it can be a headache to fix this.
Or just upload your model.
