Im am having an argumentation with a colleague about 2 options for a discharge line.
Option 1 = actual design (discharge line ending up at the hill point, then gravitary).
Option 2 = design modified (discharge line ending up to the downstream point).
He's pretending that the pumping flow rate would be higher with option 2 than it was with option 1 (using the designed pump for option 1).
I think that he's taking in account a vacuum effect that would form after the hill point. How could the flow rate be higher in option 2 than 1 using the same pump?!
