Roll-up Attributes functionality in NX: Which version
lklo
Industrial
Nov 24, 2010
226
Hi
I would like to ask, if someone here, can remember or knows, when NX got implemented the Functionality:
Roll-up Attributes
A real cool and smart "Feature" I think....
And easy to configure in customer-default..
I believe the version was in between NX 1847 and NX 2007, but not sure..
br lklo
Thanks a lot Cowski...
I just also get confirmed: NX1899
FYI:
I do have a number of NX custom applications, which are based on NXOpen.UF.UFWeight.EstabPartProps1,
but now after we upgrade from NX1847 to NX 2007, I am facing a serious "trouble", when executing NXOpen.UF.UFWeight.EstabPartProps1...
Runtime is extremely slow, during executing...
I have been using this really cool function since NX8.5 (- without problems) - when the Mass of an entire assembly should be calculated.
But for Now in NX 2007 - as a temporary workaround - I figured out, that the new "NX feature" Roll-up Mass attribute has become available in NX 2007....and then I simply replaced NXOpen.UF.UFWeight.EstabPartProps1 mechanism, with the value from the system attribute: NX_MassPropRollupMass
I'm in close dialog with Siemens DI about this: change of behaviour or maybee a bug in NXOpen.UF.UFWeight.EstabPartProps1
br Lklo
