Rollets Macro
ajay2agrawal
IN
Hello Everyone,
This is great to be a part of this forum.
I wanted to develop one macro by which one repeated commend can be minimized.
I have some sort of partern which I need to repeater more then 100x time soemtime.
I Made Power copy for it, but its not solving that much time issue.
It will be very help full if any one create Macro from Power copy.
I have also attached presentation for better understanding What I need.
if anyone can help please let me know
check InstanceFactory in your V5Automation.chm file...
Eric N.
i figured it out how to run powercopy from macro, but i never think about to make loop of it. It is kinda interesting approach.
I m think now about it, and have some ideas in my mind. So i guess you first need figure how to run powercopy from macro and then think about this loop.
One more thing, i think you need special licence for this, KT2 or something like this. You can make everything good but without this licence it will not happen.
I think you can control these two inputs with the loop.
Dim Center As Object
Set Center = PartDest.FindObjectByName("Point.1")
Dim Surface As Object
Set Surface = PartDest.FindObjectByName("Surface.1")
V5Automation.chm is inside your catia install [...]code/bin folder
Eric N.
Thank you guys for fast response
I have tried to write below code but its showing me error.
Sub CATMain()
Dim PartStart As Part
Set PartStart = PartDocumentStart.Part
Dim reference As Object
Set reference = PartStart.FindObjectByName("UserFeature2")
Catia.SystemService.Print "Instantiate the reference in the current part"
Dim factory As InstanceFactory
Set factory = PartDest.GetCustomerFactory("InstanceFactory")
Dim instance As ShapeInstance
Set instance = factory.AddInstance(reference)
Catia.SystemService.Print "Set Inputs"
Set Center = PartDest.FindObjectByName("FIRST LINE")
Set Center = PartDest.FindObjectByName("Surface.1\edge.5")
instance.PutInput "FIRST LINE", Center
instance.PutInput "Surface.1", Surface
instance.PutInput "Surface.1\edge.5", Surface
Catia.SystemService.Print "Modify Parameters"
Dim param1 As Parameter
Set param1 = instance.GetParameter("PITCH")
param1.ValuateFromString("1.5mm")
Dim param2 As Parameter
Set param2 = instance.GetParameter("OFFSET")
param2.ValuateFromString("0.5mm")
Dim param3 As Parameter
Set param3 = instance.GetParameter("FRONT_PARABOLA")
Catia.SystemService.Print "Update"
PartDest.Update
Catia.SystemService.Print "Retrieves Inputs and Outputs"
Dim inputCentre As Object
Set inputCentre = instance.GetInput("LINE")
Dim inputSurface As Object
Set inputSurface = instance.GetInput("Surface")
Catia.SystemService.Print "Retrieve outputs"
Dim outputDirection As Object
Set outputDirection = instance.GetOutput("Direction")
Catia.SystemService.Print "Close the CATPart containing the reference"
PartDocumentStart.Close
End Sub
I am pretty new to this VB scripting ,can any one suggest
