I'm curious if anyone uses this framing system in the US where beams are spaced at 10ft oc with 3N metal roof deck and how it affects utility supports.
I have two applications for this system and im concerned that it will become a problem once MEP starts going in and they are used to having supports (beams/joists) at 6ft oc.
The first is a medical office building with typical doctors offices and the other is a small scale pharmaceutical production facility.
