a roof truss with a span of 35 meters ,it will be supported on two concrete columns , the design was carried out assuming one support is pin and the other is roller ,but in the construction drawings 'the attached drawing' both ends are bolted down ,,is that ok , I have some concerns about this as the temperature changes are high in my place ,,moreover, the members near the support are not concentric, is that ok.
Finally is there any standard procedure to test the truss.
