sgs114
- Oct 7, 2013
- 33
I have a question with regards to the design of rooftop penthouses. When designing these rooftop structures, do you typically (won't say always) use Section 13.3 for design of the structure regardless of what your lateral system of the roof top structure is (ie cantilever column or metal stud walls)? Are you able to design the rooftop structures using provision in CH 12 instead to try and lower your seismic coefficient (relative to the penthouse weight)?
SGS
SGS
