jonathanwilkins
I'm working on a building that's got some water intrusion problems. So far it's only a little plywood at the corners but I've got to go check out a section where the studs are rotten. I'm guessing that I'm going to find the vapor barrier is on the inside of the studs. The building is in a hot, humid area & pretty sure this is what is causing the rot in this area. We never apply vapor barriers inside anymore.
We're going to replace the studs, plates, sheathing, etc. only in the affected area. ($$ is tight). Would it be best to have no vapor barrier at all or add tyvek to this small section that's being uncovered? Obviously it would be best to fix this everywhere but that's not currently an option.
