ROUT
controlnovice
Is it very common to use the ROUT of a controller?
I just ran across this in a plant. The engineer said he could not tune the controller (in a DCS) to behave how it needed, so he developed three different equations to determine valve position and sends it to the ROUT of the controller.
My concern is that once this engineer leaves, nobody will understand where these equations came from or why a controller is in ROUT (since it doesn't seem that common).
The plant does not have a process controls departmemt or group or anything to support the DCS.
Doesnt not sound familiar. Is there a reason he cannot use the PID to tune the controller? I have yet to see a case where you cant. But theres not enough info to determine that.
What kind of loop is he trying to tune and what DCS are you using?
I wouldnt let him go to far without a detailed explanation.
Just post a little more info. My search is not coming up with much.
Good Luck!
Quote: "Its not what you know, its who you know"
Everythings a learning experience-Everything
