I'm starting to be interested in the DO-160 of avionic equipment.
I would like to know if there is something, a document for exemple which define the proper Category depending of the criticality of the Equipment (Major/Hazardous...). In particular for section from 17 to 23...
If not, How can I defined if the equipment is properly qualified other than to say that the equipment is already installed on other aircraft ?
The idea is to to write next to each category saying that the equipment is properly qualified for XX reason.
It's a really wide question but hopefully you guys will be able to help me
Thank you very much
Thank you very much
