I have an application that connects an API 6A Type 6B RTJ Raised Face flange to an API Type 6B RTJ Flat Face flanged choke valve.
Does any one have experience, or see an issue with mating a RTJ Raised Face to an RTJ Flat Face flange? I know that this is not recommended for typical RF/FF connections, but we would be using an RX type gasket and the RTJ faces are not meant for face-to-face makeup. My initial thought is that since the faces do not touch and both flanges are of the same material, that the mating between the two would be acceptable.
Thank you in advance!
