EngDM
- Aug 10, 2021
- 682
Quite often when designing steel studs I come across the need to use either Simpson or Bailey clips. However, aside from a select few Simpson clips, all resistances are for allowable loads. Is there a rule of thumb I can use to compare by factored loads vs the allowable loads for the product? Typically I just compare my factored to the allowable which seems way conservative since I'm factoring loads and factoring down the clip capacity, but there are certain cases where the client requested clip cannot work unless I compare unfactored LSD loads.
Has anyone rationaled this to themselves for a safe but not overly conservative approach?
