Running a DOL starter from a VFD
Greymoonstar
Marine/Ocean
Jan 30, 2025
I am trying to run a DOL starter for a Marine Hydraulic Power Unit.
The Starter runs a 220V 3-phase 60hz 2.2kW motor.
I am in the UK and my Factory supplies are 230VAC Single Phase and 415V 3-phase.
I have tried running a VFD as the supply to the starter, but when I engage to motor contactor in the starter, the VFD triggers a constant speed overcurrent error and cuts the supply.
The starter will not allow the motor contactor to engage without 3-phase, but if the vfd is running before I start the motor, it errors and cuts the supply.
Any ideas?
(First time poster)
The output of the VFD should go direct to the motor.
Sounds like you have the contactor in between the motor and the VFD output?
There are usually interlocks between a VFD, load side disconnect and the VFD itself (I've never used a starter on the load side of a VFD, but have installed disconnects on the load side of a VFD for local isolation). Drives don't like switching actions on the load side of their terminals while a load is being driven, hence the VFD cutting out.
Mike
A couple of questions.
Why are you running a 60Htz machine of such small power in 50Htz land?
If this is a DOL starter, why not use a 50Htz machine?
Or if you really want to just use a 60 Htz machine buy a static convertor https://powersystemsinternational.c...c-frequency-converters/50-to-60hz-60-to-50hz/
Or just plug in your VFD to the machine direct and tell it to ramp up in 5 seconds or whatever the minimum is on the VFD control.
Sounds like you're trying to use a VFD controller to give you 60Htz, then plug in a DOL starter which is going to give you 4-6 X FLC as a starting current so not a surprise the VFD unit doesn't like it.
What's the details on the VFD unit?
The HPU and DOL starter are for a marine steering system for a vessel in South America. The onboard power will therefore be a 60hz 3phase from their generator direct to the starter. So the contactor will be the only control element for the motor.
But I need to test run the system for the classification society surveyor before it gets sent to the shipyard for installation. Hence the need for running a 220V 3ph 60hz supply into the starter, I have to prove all it's safeties and backup systems function correctly.
I have a converter for 415V 3ph, but it's min output is 380V and the vessel can't supply that (I believe it is a refit to an older vessel, so no upgrade to the power supply)
If you can get 380V 60 htz then all you need is a step down transformer?
At that power you sound be able to hire one?
OR hire a 220V 60 Htz generator.
Your VFD is just not set up to do a DOL start.
