Duwe,
I agree with you that it is a Pressure Relieving Device, it is required to be qualified and that it holds up to a specified pressure and therefore is a pressure retaining item. However, if the disk has ruptured it will not retain pressure. It is in this context that I said the disk was not pressure boundary (or pressure retaining). It is not external pressure boundary. I may have missed the context of Alex2010’s post.
Is the disk itself considered a PRD or is it the disk in conjunction with the holder? It is the disk holder forms part of the pressure retaining piping.
Is pressure retaining material required to be Code Material? Rupture disks do not need to be Code Material.
The disk itself does not require individual registration (in my world these are registered) but the disk holder requires the registration.
Some sections of the CODE require that the disk is stamped with the UV symbol and other sections do not.
Some sections of the Code require the use another PRD in line with the disk whereas other sections do not.
The reasons for the differences between the various sections of the CODE noted above are unknown to me. I have posted in thread292-284594. Any insight there would also be appreciated.
