Feb 2, 2003 #1 gcimob Mechanical Feb 2, 2003 1 0 0 US I need the stress for SA-212B-Fbx. This material is 36 years old on rolled plate for a pressure vessel. Temperature is 170F
Feb 6, 2003 #2 ijzer Materials Oct 25, 2002 313 0 0 NL Per ASME VIII-1 Ed 1962 17500 psi Upvote 0 Downvote
Feb 10, 2003 #3 McHaney Materials Dec 9, 2002 3 0 0 US SA-212 Grade B was replaced by SA-515-70. Reference to the current allowable stresses for SA-515-70 may be useful for your needs if you do not have access to the out-of-date editions of ASME Sect. VIII. Upvote 0 Downvote
Feb 10, 2003 #4 LSThill Mechanical Oct 10, 2002 1,120 0 0 US Hi gcimob (Mechanical) I agree with ijzer (Materials) and McHaney (Materials), I had a #50 Crude Unite Built in 1941 with the same question. Check the Material Certification I have seen the MTR cover SA515-50 THRU SA516-70. Upvote 0 Downvote
Jun 18, 2003 #5 cgr New member Feb 28, 2002 3 0 0 CA Can anyone clarify exactly when grade A212 Grade B was replaced by SA-515-70 (in what edition of which publication)? We are modifying an old pressure vessel and we need to submit documents to satisfy our client that the materials are indeed equivalent. Upvote 0 Downvote
Jun 19, 2003 #6 ijzer Materials Oct 25, 2002 313 0 0 NL A 212 was discontinued and replaced by A 515 / A 516 in the year 1962. Upvote 0 Downvote
