Saddle Calculation L.P. Zick vs Compress
Ehiman1
59
I was studying calculation of stress in vessels on two saddles but I can't understand the first formula!
If I read "Stresses in Large Horizontal Cylindrical Pressure Vessels on Two Saddle Supports" by L.P. Zick you can see the value of longitudinal stress S1 from the following formula:
In Compress this formula is different, because you have to divide "Lenght/12", and I can't understand why!
Does someone can explain me why there is this difference between Compress and L.P. Zick formula?
Many Thanks
I would assume a unit conversion from feet to inches or vice versa, depending on how they define L and R.
Also, there have been some updates made to the original Zick paper, some by Zick himself, I believe, others by various pressure vessel handbook authors, so you may have to compare several sources to make sense of everything. User notes/help on the program may help as well.
Thanks JStephen, the problem is I use S.I. metric so I have mm and not feet or inches!
I am thinking Compress formula is wrong! Because if I calculate in S.I. system I don't need to divide L/12.
In Zick's paper L is the length in feet, so if Compress has L in inches then it looks that's what they're doing.
However, there is very likely a unit conversion hidden in the "3" of Zick's equation. Since L is in feet but S1 is in psi there should be a 12 inches/foot conversion hidden in the constant. I would run the calc once with your values converted to the units used in Zick's paper, and once with your metric units. It's likely the answers won't match. I would extend this philosphy to the entire Zick paper.
As an example of hidden units in the constants of a formula I would suggest reviewing the shell thickness formula in API 650. In Imperial it's 2.6D(H-1)G/Sd but in SI it changes to 4.9D(H-0.3)G/Sd.
In looking at Zick's paper, it looks like he divides moment in foot-lbs by section modulus in inches-cubed. There is a 12 factor incorporated for the units, which gets broken up into a factor of 3 in the equation and a factor of 4 included in the definition of K1.
Many thanks!
I have another question to you. I don't understand how can I find out the following value of K1'
It isn't K1 of S1 and I don't find anything from L.P. Zick.
Did someone find the meaning of this coefficient?
You could also review the method in PD5500 Annex G, it is in metric units and includes relevant updates.
