SAFE 21 Modelling Help!
eng.chix
CA
First project in SAFE 21 since its newest release. I'm already having problems with items that used to be super simple.
I'm trying to model a portion of the slab that has a vertical offset of 1500mm from the main slab. The main slab has balconies cantilevered off it with the offset slab continuing beneath the balconies. If I use the insertion point option, it doesn't appear to actually drop my offset slab below the balconies. It creates 'cutouts' on my offset slab where the balconies above are cantilevering off the main slab. Are there ways to fix this, or is this something that has to get modelled in ETABS instead?
Thanks for any advise!
