Thisforumishacked
Materials
- Apr 9, 2020
- 4
Hi all pipe stress engineers!
I have a general question regarding safe lifting of pipes in operation at an offshore oil&gas installation (FPSO). A typical problem is corrosion at the contact point towards pipe supports, where access is restricted for both inspection and maintenance. The preferred way to handle this is to lift the pipe a bit to perform inspection and maintenance/coating, and since production normally cannot be stopped everything needs to be done safely while the piping is in operation. I'm looking for a general way to justify safe lifting based on good engineering practice, formulas and standards (not just "gut feeling"), for example something that can be put inside an Excel sheet where we put in material, diameter, wall thickness, etc.
The lifting location will be completely free to move (support removed), but I assume we will need different formulas for different neighboring pipe support types, e.g. anchor, guide, axial restraint. I will be able to find piping isometrics (i.e. diameter, wall thickness, material) and design code for the pipes to be lifted (normally ASME B31.3), but unfortunately not stress isometrics or computerized models.
What we typically need to know is either:
[ul]
[li]We need to lift e.g. 40 mm to perform maintenance, what is the minimum required free length required before the next fixed location (support)?[/li]
[li]We have a distance of 4 m to the next pipe support, what is the maximum allowable lifting heigth?[/li]
[/ul]
For straight pipe lengths I hope this will be fairly easy to calculate, but I'm not sure what formula to use or what to specify as maximum allowable stress in the pipe (e.g. 90 % of SMYS?). And also, what can we do to simplify calculations for pipes with branch connections or changed geometry (typically one or two 90° bends) before the next support? As a start, we can live with some conservative simplifications if that makes calculations simpler. For example consider all supports as fixed, or even also consider all bends or branch connections as fixed. Then if the calculations cannot justify lifting, we can look more into each case separately to see if it's too conservative.
I would greatly appreciate input from someone with experience in this subject, since it's not easy to find much information on this online![[glasses] [glasses] [glasses]](/data/assets/smilies/glasses.gif)
[ul]
[/ul]
