E.OGull
- Jul 14, 2021
- 4
I have to design a safety net to contain glazing panels that may fail and fall.
The manufacturer indicates a netting absorption energy.
Initially I thought that if the potential energy of the falling glass exceeded that netting absorption energy, the net would fail.
Then a colleague corrected me an said that the absorption energy means the energy the net itself can take without transferring it to the supports where the net is fixed.
Hence he said "if the energy of the glass does not exceed the netting absorption energy, the supports are to withstand the dead weight of the glass only".
Is the above correct? Would not be always be an additional (on top of mass x gravity) force on the supports, regarding how low the energy transmitted by the glass was and the elastic constant of the net?
Thank you.
Thank you.
