jcsmith13
- Dec 6, 2010
- 1
I am working on a plan to backfill a double collar vertical vent shaft and need to be able to work directly over the shaft to determine where to find competent rock within the shaft and later to construct a foam plug within the shaft.
My concern is with the shaft sloughing around the collar. We are planning to use fall arresting systems on workers but I think some sort of truss crossover is needed for work over the shaft. I wondered if anyone else has used this type of system in the past.
Thank you,
Jason
Thank you,
Jason
