I am doing an evaluation with the thermal conditions (expansion coefficient) on - same temperature for the whole assembly - and other without thermal conditions - meaning that a constant temperature is given in both load cases, but thermal expansions are off (using APDL snippet) in the second load case to evaluate primary stresses. The first load case will give primary plus secondary stress since we have the thermal load (expansions coefficients on).
When I see the equivalent stress for the thermal load case and compare it with primary load case, the stresses increase for the primary plus secondary load case even though the assembly is at same temperature i.e. all parts have same temperature and same material properties.
If everything is at the same temperature and same material properties this should not happen. or is it because of bonded contact in the model and bolts modeled as beams, some boundary conditions constraints. Note that boundary conditions are same in both load cases.
Shiraz
Sr. Engineer
Shiraz
Sr. Engineer
