Client wishes to convert a totating kiln, counterflow grain dryer to a sand dryer. The sand is aproximately 5% moisture, and they want to dry to less than 1% moisture. How do I determine the heat required and the airflow rate required through the dryer.
they wish to dry 90 tonnes/hr.
the dryer is 1.5m in diameter and 8 m long.
Do not know the rpm available.
Do know they have a 18,000,000 btuh oil fired burner.
