Why during sand equivalent test the reported value should be taken to the nearest higher whole number..is there any scientific reason for that or its just for the purpose of ease..thanks
Does one really think the test is so accurate and the number so technically useful to worry about decimals of a whole number. Liquid Limit and Plastic Limits are reported to the whole number too and an argument could be made that these tests' results are more "accurate" than whole numbers.
Yes sir your thoughts are nice...but why not to the nearest small whole number? Why always next whole number..example 7.1 should be reported as 8 why not 7.
Because in maths if you are 5 and above you round up.
Why would you report 7.1 as 8? I think that maybe you are thinking that rounding up to 8 may be more conservative. I dont think that is correct as parameters being higher or lower can be conservative or unconservative in specific applications.
Ron I routinely see atterbergs to 2 decimals. Same with settlement, we have many clients that wont accept a bearing pressure if its 25.2mm. HAS TO BE 25mm OR BELOW!!! Some ppl just dont get it.
And also Geokhan, you need to start giving some more information with your questions. What "sand equivalent" test, BS, ASTM etc? In many standards there is a requirement of the standard to report numbers in a certain fashion.
