I use turbine meter for oil and water legs on a 3 phase separator for shale oil and gas production. the sand sometimes messes with the turbine meters and stops it from working. sometimes, operators will tap on the meter with an instrument and it start working again.
apart from dealing with the obvious (sand), are there other recommendations for the same meter (Nuflo turbine meters) or alternative meters that could help with this kind of behavior?
As much as possible, do it right the first time...
