sand shear
PatrickFeeleus
6
assuming Medium Subrounded SAND (0.25 - 0.5 mm) i would like to estimate the force required (virtually staight pull) to remove an umbilicle burried at 0.8m at a 30meter water depth.
Could someone point me in the right direction please?
thanks
Patrick
The water depth will not be a factor. The diameter and length will be a factor. This may be a case where a drawing would help (it's kind of hard to visualize the problem).
f-d
¡papá gordo ain’t no madre flaca!
