Sandstone Block Retaining Wall 2
CSEng-Au
1
What books or resources would you recommend for the calculation of the sliding friction resistance force of sandstone blocks (between two blocks) in an earth retaining wall?
If you are doing MSE wall (reinforced earth retaining wall), the linked paper may help.
Link
I did a granite one down in Georgia about 45 years back and recollection is fuzzy. I seem to recall that it was about 20' high and 13' wide at the base. There was a masonry 'book' back then that had construction of ashlar walls.
Dik
See link from the Foundation Engineering forum; scroll top the post by PEInc
Link
A while back I did a stability analysis of a sandstone stairway. The geotch initially said 0.5 but a lot of the stone was badly weathered so we decided to use 0.4
