BlackSmoke
Chemical
All, I am working on a biochemical process service where both flammable solvents and a sticky substance requiring frequent cleaning are used together. Sanitary clamps (<2" diameter) are desired to facilitate disassembly and cleaning, and I have been asked to confirm that they can be used in this service.
I have heard anecdotally that such clamps were used in ethanol plants, but otherwise in my experience they are rarely if ever used in petrochemical service. I can understand why I would not want large diameter sanitary clamps in these sorts of services, due to low pressure ratings and potential for material to collect on the clamp body while disassembling. My research has turned up no reason that these clamps could not be used in this type of service in a well ventilated environment, and vendor rep I spoke with preferred not to comment, and I'm waiting for a response from another supplier.
Is the group here aware of any code, standards, or other practical limitations that would prevent the use of sanitary clamps (Tri-clover, tri-clamp, BPE-pattern, etc.) in flammable liquid or vapor service?
