Are they the same? Assuming the selected location for point load is at the same location as 0 Relative Distance of the frame load. Compared to the point load I apply at 0 Relative Distance of the said member.
The difference I see now is that, if I apply as joint load, it will show in the joint load window and if I apply as a frame point load, it will appear in the frame load window. Will it make any differences? What I'm doing is applying wind load in a specific direction.
Thank you very much!
