SAP2000 Modeling Question
Keystation
I am making an x brace that is connected by a plate in the middle. However, it's not 4 individual members joining together in the middle. Two members are just crossing each other connected by plate in the middle to reduce unbraced length.
If I were to make 2 elements crossing each other, unbraced length is not accurate. However, making them 4 individual members will allow all 4 of them to act independently.
How would you model this in SAP?
Cant you manually specify the K factor to be used for column design in sap?
AISC SDM x-brace example has some commentary on the K factor for braces connected at the middle node.
Depending on how many of these you have a simple hand calc of the braces might suffice where SAP 2000 design checks are not serving you well.
