Hi all
I made a gui window for calculating some parameters. When I run the gui program, I insert the inputs in editable boxes and push the "Calculate Outputs" button, then The answer is displayed in the embedded boxes. My Problem is that when I close this gui window and open (run) it in the next time, the inputs reset and return to default values. Is there any way to keep (save) the input numbers in the another file for call them the next time ?
Similar to command: File-Open
