Save options desaster
Bogdan1985
72
NX8.0
Hi Friends,
I clicked something else. Now a hole assembly cannot be loaded. What are the loaded options to open all parts I like without error message? Means, is there a golden trick to open all the thinks I like without to care about any options?
Thx
Hi Bogdan,
I think you mean NX can't find the child part files in Windows folders - is that right?
If so:
Check File > Options > Assembly Load Options
- from folder means all files are in the same folder as parent assembly
- as saved means they are in their original saved location
If the folder has been renamed / moved in windows, you may need to browse for the files, and then save assembly.
Buna Bogdane,
Load Option este ceea ce tu trebuie sa aplici......
CAD 2015
@ CAD2015
Mulțumesc, dar o să mă înnebunesc din nou.
@ Calharr and Toost
My coworker fixed this problem partly. He used the option "Search Folder" and he add all folders I have.
The other way with the parents-folder does not work.
Because I made a mistake and saved the parts on a stick instead to save it normal and then to
copy to my stick.
So this problem is solved, with a little more work.
Thanks to All!
The best way is to save all the files in the same directory, so NX and user don't have to look somewhere else to find missing files. Sometimes when path is not set correct NX save files in UGII dir.
With best regards
Michael
