Hi. I have a question regarding the welding of A333 materials.
In our "Piping Material Specification (PMS)" the welding type for welded A333 Gr. 6 pipe was specified as SAW but according to ASTM A333 no filler material shall be used for the welding of this material:
Now, the vendor claims to have provided the same pipe as specified in PMS (SAW A333 Gr. 6). However, it is not inspected yet so I am not sure what the material really is.
I want to know in case the welding is really SAW, will it cause problems to the material and should we reject the material?
I also do not understand why the standard prohibits the use of filler for welding of this material.
"4.1 Manufacture—Except as provided in paragraph 4.2, the pipe shall be made by the seamless or welding process with the addition of no filler metal in the welding operation. Grade 4 shall be made by the seamless process.
4.2 Grade 11 pipe may be produced by welding with or without the addition of filler metal. The following requirements shall apply for Grade 11 welded with the addition of filler metal."
